nordonian Posted August 10, 2006 Posted August 10, 2006 got my 3g brakes today in the post, can someone plerase post a step by step guide to replacing the discs. I changed my own pads last time so i know how to do them, just the discs i need talked through. Quote
whitestarlet Posted August 11, 2006 Posted August 11, 2006 remove the wheel and the 2bolts that hold on the caliper . there are 2 bolts nearer to the bottom of the strut either 19mm or 21mm i think. remove them and the caliper bracket will lift off. fit the new disc and rebuild up again. hope that helps Quote
nordonian Posted August 14, 2006 Author Posted August 14, 2006 easy peasy. was nothing to it once i knew wat i was doin, i have to take the wheel off again to paint the calipers black, thanks mate Quote
