hey my clutch has recantly started slipping and ther is a metel on metel vibration noise also coming from sumwer but im not sure if the noise is sumin to do with the clutch on its way out and sumin els goin with it??????ive had a look and cant seem to locate it as it only happens wen im driving at a certain rev any help would be much apreciated
thanks luke
could be the rivot's on the clutch grinding into the flywheel dude, best to get it done asap, before you need a new flywheel too
cheers dude i am gna try and nt drive it any way till i sort the problem :)
