alright people.
Fitted a 2nd hand hks actuator today...firstly it was the hole type and mines the pin type, so bought a pot rivet with a hole in the end of it (put a lock clip through it) done and done. I've read through the forums (old and new) when it comes to the t-piece ( i need to save money!) do you just put the 2 pipes onto it, then run a new pipe down to the actuator?
from efi ------>_______<-------- from turbo (think thats right)
| <- to actuator
(HKS)
Thanks in hand :lol:
All depends if you can live without lo boost.
Personall I got rid of it and all the other vacuums lines as I was running a front mount filter and FMIC.
So yea just block the one going to the solenoid, makes liek alot easier :lol:
suppose i can! Ivve blocked up the other pipe, and shortened the arm as much as i can and it still wont boost, in any gear, more then 9 psi.
any one got any ideas? all pipes are tight etc
