Asad Posted December 13, 2009 Posted December 13, 2009 Hey,Been looking into ITBs for my N/A....having done a little research i`ve worked out the followingGet suzuki itbs 700/750 variantchop up old manifold and join both with silicone joiners add V-stacks (all to the correct length in order to get it all to fit/air flow etc etc)block suzuki injector holes, attach fuel rail/injectors and attach the set-up to the headconnect all the vac hoses to some sort of cylinder and run a line tomap sensorto the little fuel thingy on the fuel railbrake booster (could also run this off one of the suzuki injector holesuse the stock suzuki tps (depending on the values it puts out) OR mod N/A one to fitmod the throttle cable to fitAnd thats as far as ive got......anyone shed some light on anything i`ve missed?will it work?can the engine take it?will i NEED standalone to control fueling/ignition?Asad Quote
Guest Enzo Posted December 14, 2009 Posted December 14, 2009 On th iPhone. It cqan and has been done before and you woul need a pigg back to get it working properly.Also the length of the runners would be vial to how it runs and where it produces it's power.From what you have wroteyou know more about this than most.Do you have the parts? Quote
Asad Posted December 14, 2009 Author Posted December 14, 2009 Yup, read about the length of the runners somewhere....minor issue eeeeeeeeeeekkkkkkk didnt want to hear the word piggyback= money IF this will work it will take me a couple of days to get the parts and a day to fit which is no problem i have enough money to bank role this just that now you mention piggyback its whats going to hold me back now.... Quote
Jae-Glanza Posted December 14, 2009 Posted December 14, 2009 What Gains will this see? any other benefits? Quote
The_Notorious_C_A_T Posted December 14, 2009 Posted December 14, 2009 Gains are mainly to be had with a wilder cam, as itb's prevent charge robbing in the plenium.Although even with standard cam, I have seen gains but thats with inlets and bodies that have been researched with flow, inlet length, velocity stack length and matched to the ports on the head etc etc. Quote
mcbeal Posted December 14, 2009 Posted December 14, 2009 give bogg bros a call they specialise in making inlet mani's to suit bike carbs.im sure it was around 250/300 for a mani and to get the carbs fully cleaned and rejetted to suit your vehicle.i gave them a call when i had my lupo as i was gonna do itb's on the 1.6 and see what power i could get but the car had a fly-bywire throttle so wouldn't work on the bodies whereas im sure a starlet would have a cable throttle?heres a link bogg brosguy seemed to know his stuff and will give you a good idea wether or not its gonna be within budget or worthwhile....edit:im sure all you need to do is send them an inlet mani gasket and they will make it up and send them out to you if you live far awayi was recomended to use blackbird bodies just to give you an idea of how much they cost....blackbird bodieshope this helps Quote
Sparky Posted December 14, 2009 Posted December 14, 2009 What Gains will this see? any other benefits?These are for n/a cars but with a plenum made up could be suited for turbo's I suppose Quote
mcbeal Posted December 14, 2009 Posted December 14, 2009 These are for n/a cars but with a plenum made up could be suited for turbo's I supposewhat are the benefits on a turbo car? Quote
Sparky Posted December 14, 2009 Posted December 14, 2009 flow more air into the engine basicallyBut like most other mods its pretty much useless unless other parts are modified etc.Ideally with ITB's you want a ported and polished head, yes the ITB's will flow alot more are but its still being resticted by the head, also bigger valves and then a high lift cam and it would be a screamer. Quote
mcbeal Posted December 14, 2009 Posted December 14, 2009 flow more air into the engine basicallyBut like most other mods its pretty much useless unless other parts are modified etc.Ideally with ITB's you want a ported and polished head, yes the ITB's will flow alot more are but its still being resticted by the head, also bigger valves and then a high lift cam and it would be a screamer.sounds only worth doing it when everything else has been covered not something youd do to a 4efte running a ct9 lol Quote
Jae-Glanza Posted December 14, 2009 Posted December 14, 2009 Yea, i wouldn't convert my Glanza or probably any other car. was just curious really. Learn a shed load on this forum. Quote
greenmac80 Posted May 4, 2010 Posted May 4, 2010 could you not perhaps use 4age 20v throttle bodies?they are 50mm i believe. and make a plate to bolt em up? these can be had for a cheap as 200 AUDor would they be too big? in which case you could use two instead of 4? Quote
