hi
im after a cv joint for my starlet glanza and i need to no how many splines are on the n/s cv joint it has abs and its a 1998 model just hope someone could help
many thanks dean
hi
many thanks dean
i just done one on mine recently and i had the wrong one to start with so i went for the 30 spline hub side and the 30 spline shaft side , then you will need to know what size abs ring you have and theres 2 choices but i would get a cv joint with 30 splines ether end and a 11mm abs ring ebay list all the choices :thumbsup:
http://shop.ebay.co.uk/?_from=R40&_trk...-All-Categories
thanks for your help lads , jus come up with a good idea , had a bit of a moment , as i work at toyota il order a genuine cv joint of my vin number count the splines then send it back n buy a cheaper one of ebay lol il post the count for people in the future , dno y i didnt think of dat earlier
thanks anyway
