Nayls Posted January 8, 2010 Posted January 8, 2010 Do all starlet's have the same seat subframes?Basically i have some bucket seats that i want to mount but have no frames,so i was planning to just chop some seats of some standard frames & weld the seat to it.do only glanza seats bolt in a glanza? or can i take them from a n/a of the same year & what about ep82's?Thanks Quote
Guest cheshireglanza Posted January 8, 2010 Posted January 8, 2010 n/a starlet frames fit not to sure bout gt i think there the same Quote
Georgie Posted January 8, 2010 Posted January 8, 2010 what buckets are they because i got corbeau ones and the frames had to be made n welded in etc took all day lol Quote
Guest cheshireglanza Posted January 8, 2010 Posted January 8, 2010 what buckets are they because i got corbeau ones and the frames had to be made n welded in etc took all day loli sold some corbeau bucket seat frames took hour to make the frames and frames moved so you could move seats if you were short ass can get some more made up but i would need frames and one seat and to confirm there good ask batman glanza on here has he bought set off frames on here plus bucketep91 bought frames but they seem to have got lost in post Quote
Georgie Posted January 8, 2010 Posted January 8, 2010 they only took u an hour did u say? lol mine were a mission and just about fit in, the passenger one is welded in you cant move it but mines on runners because im a short arse but its quite high because thers like 2 frames underneath it, i wana change em to impreza seats really and try and get em lower, du know if they would be ok for me, as id need em to pump up lol Quote
Guest cheshireglanza Posted January 8, 2010 Posted January 8, 2010 im not sure but i used the standard ep91 frames so they sat nice and low need batman glanza to log on to confirm they sat right may be able get him to get pic off frames how i did it Quote
Asad Posted January 8, 2010 Posted January 8, 2010 Where are you guys mounting the seatbelt buckle for these seats? any pics?? Quote
Guest cheshireglanza Posted January 8, 2010 Posted January 8, 2010 ^^ were the seat rail bolts to the floor get the buckle off your old seats then bolt long side rail this shit pic only shows top off buckle Quote
Asad Posted January 8, 2010 Posted January 8, 2010 so? the buckle is just drilled into the side of the old starlet rail??? Quote
Guest cheshireglanza Posted January 8, 2010 Posted January 8, 2010 no along side the rail were it bolts to body seat belt buckle hole is same size has the one in the rail so bolt gos straight throught both off them Quote
Asad Posted January 8, 2010 Posted January 8, 2010 Ill go have a look at mine see if i can figure it out, thanks bud Quote
