Spanner Posted January 8, 2010 Posted January 8, 2010 hi guys and girls, just a couple questions,im planning on fitting my boost gauge and was wondering if anyone has a pic of where they joined the t-piece under the bonnet?also what is stock psi on lo-boost and hi?i noticed that since i fit my induction kit,this cold weather is inducing fuel cut quicker, worse for it is in 3rd under load, will this clear up when the air is warmer outside or should i go back to the airbox for now?thanksCarl Quote
paulgtt Posted January 9, 2010 Posted January 9, 2010 hi guys and girls, just a couple questions,im planning on fitting my boost gauge and was wondering if anyone has a pic of where they joined the t-piece under the bonnet?also what is stock psi on lo-boost and hi?i noticed that since i fit my induction kit,this cold weather is inducing fuel cut quicker, worse for it is in 3rd under load, will this clear up when the air is warmer outside or should i go back to the airbox for now?thanksCarlHi mate,I tee the boost gauge line into the dumpvalve vacuum hose normallyStock psi is around 5 on low and 8 on hi, its been a while since Ive had my Starlet but IIRC thats about right!!This is down to the weather yes, do you have a decat on the car?? Quote
Michel_M Posted January 9, 2010 Posted January 9, 2010 Mine is fitted like this (t-piece just behind the oil filler cap):But obviously it doesn't really mather were you put it I suppose, as long as its the right hose lol. Quote
paulgtt Posted January 9, 2010 Posted January 9, 2010 ^^Thats how I do my boost gauges, just tee it into the dump valve vacuum hose Quote
Spanner Posted January 9, 2010 Author Posted January 9, 2010 Wow thanks for the feedback guys, exactly what I needed! As for decat, I think it's the standard item but I don't know if the inners have been removed or not.it has a blitz system fitted tho.think I will just refit the standard airbox for winter then thanks for the comments guys.oh and mich, pic was aweome, also noticed your intercooler cover has cracked in the same place as mine lol Quote
Spanner Posted January 14, 2010 Author Posted January 14, 2010 A quick update guys, I fitted my boost gauge today and was very suprised, I'm running 12psi on full boost,is this normal?I spoke to ep82-girl and apparently it's pretty high considering the only mods I have are a blitz nurspec,blitz bov and an induction kit.any ideas? Quote
chr15_7_t_ Posted January 15, 2010 Posted January 15, 2010 depends how acurate your boost gauge is to mate... i no the one on my car is ever so slightly out Quote
