joe GT Posted September 6, 2006 Posted September 6, 2006 ALOHA! does anyone know what i should set my FSE fuel regulator to in PSI, both under vacuum and without?? this would be a great help, and very much appreciated. thanks for your time.joe GT Quote
DaMaGe Posted September 7, 2006 Posted September 7, 2006 What boost, what injectors, which fuel pump and what turbo are you using ? Quote
joe GT Posted September 7, 2006 Author Posted September 7, 2006 CT-9A turbo, standard pump and standard injectors. i'm running at 1.2 BAR boost with a fuel cut defender and front mounted large intercooler, full A'pexi exhaust system with decat. whats the safe amount of maximum boost to use? internals aren't standard, but i done want to over-run it. done 35,000 miles too. thanks alot for your help. Joe GT Quote
ecksjay Posted September 7, 2006 Posted September 7, 2006 1.2bar without fuelling mods? well, if you havent already broke something, then you aint far off mate, the stock turbo turns into a hairdryer at a little over 1bar, plus with no fuelling you must be running dangerously lean like that... Quote
joe GT Posted September 7, 2006 Author Posted September 7, 2006 fair enough... anyway, anyone tell me what PSI i should set the regulator to? cheers Quote
DaMaGe Posted September 7, 2006 Posted September 7, 2006 Put it to 1.1bar of 15-16psi and adjust the fuel to 43-45psi on idle with vacuum line connected. You wont have any problems mate Quote
joe GT Posted September 8, 2006 Author Posted September 8, 2006 thanks alot mate, your a star! fitting it tomorrow, so i'll let you know how it goes... prob the wrong section to ask this in, but is anyone going to the isle of wight bestival? or did anyone go to the isle of wight rock festival this year? i live down here, and you should all come over sometime, its a great place to drive around and get pics of the car. anyways, thanks for your help dude. joe GT Quote
DaMaGe Posted September 9, 2006 Posted September 9, 2006 PS. Put your fcd setting on 8 mate aswell Quote
