Nads Posted January 24, 2010 Posted January 24, 2010 Hey guys..I got the d2s and already they are making a banging noise when going over speed bumps or drains in the road!!!!if this a common problem or is there something i have to do?? Please help Quote
Idrees Posted January 24, 2010 Posted January 24, 2010 Make sure all the bolts are tight. One of my K-Sports once did they same and I found that the bottom bolt on the rear shock was loose, tightened that up and it was all good! Quote
Glanza_cl Posted January 24, 2010 Posted January 24, 2010 well everyone did tell you have you played with the springs at all? you might have left them a tad loose with like 0 preload and there moving around on the damper slightly.have you had them properly set up? like camber, alignment ect... if not you need that done soon.or just sell them and get BC's lol Quote
Nads Posted January 24, 2010 Author Posted January 24, 2010 Haha i know i know.. big mistake if they are fuckedWell Ive tightened everything i can see on the shock... Ive had the car aligned.. but not cambered yet... but even if i did have all that done! i shouldn't be making that banging noise..like Metal to metal noise !! Quote
