what the standerd pressure of the fuel rail using a standard reg and what should you raise it to once you have a fmic fitted and a fcd,should you also need a boost controller to up your boost, Also i have 7mm ht leads hks mushroom filter gutted cat longlife centre section and apex megaphone backbox any help much appreciated.
