paul mc Posted February 7, 2010 Posted February 7, 2010 changing into 1st and 2nd gear has recently start 2 grind possiable synco someone told me if it was what would i need 2 replace it and how much would it cost ? Quote
paul mc Posted February 7, 2010 Author Posted February 7, 2010 Can anybody advise me on this any help is welcome . Quote
Idrees Posted February 10, 2010 Posted February 10, 2010 Hi mate,Your best bet is to contact a local gearbox specialist. You can probably find one on Google or Yell.comI did this and found one 15 miles away. I bought all the gear syncros from Toyota, which cost me around £120 and the labour worked out to around £150.You can buy the second syncro for around £20-30 as far as I remember. Contact Toyota with your chassis number and they should sort them out for you, if that fails then check out the part number section.Good luck mate. :surrender: Quote
Nick@TD.co.uk Posted February 10, 2010 Posted February 10, 2010 Give us a call and we will happily get a quote together for a gearbox strip down and also try and price up a good condition used box including fitting for you.Just let us know were available via PM, Email or Phone :surrender:Kind Regards, Nick JonesTuning Developments LTDWorkshop Landline - 01925 822266TuningDevelopments@Hotmail.comwww.TuningDevelopments.co.uk Quote
Guest cheshireglanza Posted February 10, 2010 Posted February 10, 2010 got used gearbox £100got used gearbox £100 good con Quote
batmanglanza Posted February 10, 2010 Posted February 10, 2010 got used gearbox £100got used gearbox £100 good congot a gearbox for sale mate Quote
