Fitted my rocker cover from dave b and it has two breather outlets on the cover that go to a catch can. So when i took off my old one and took the pipe off the pcv valve i blocked off the little port that it went to on the inlet mani, was this the right thing to do? Also since fitting, when on full load, as i change gear i get an extra woosh sound that sounds like its coming out of the catch can, has only done this since fitting, cant think why it would be doing it!
