Crossfade Posted February 18, 2010 Posted February 18, 2010 Smoking problem on my ep91 glanza . The turbo boosts fine but it is munching oil and blue smoking from the exhaust system . It doesnt look like rings but i could be wrong . If anyone knows any comon faults with the ct9b or of the 4efte engine has comon faults . I will be honest i havnt got alot of knowledge in the starlets . Im just worried if i could get some advice or anything i should check out that wiuld be awsome . I also sometimes get a high pitched whining noise on hight boost also a aftermarket adjustable actuator has been fitted and the poor little ct9b has been boosting to 12psi from what i have been told they dont have a long life boosting at that pressure ? Thanks Matt . crossfade Quote
Carl. Posted February 20, 2010 Posted February 20, 2010 Smoking problem on my ep91 glanza . The turbo boosts fine but it is munching oil and blue smoking from the exhaust system . It doesnt look like rings but i could be wrong . If anyone knows any comon faults with the ct9b or of the 4efte engine has comon faults . I will be honest i havnt got alot of knowledge in the starlets . Im just worried if i could get some advice or anything i should check out that wiuld be awsome . I also sometimes get a high pitched whining noise on hight boost also a aftermarket adjustable actuator has been fitted and the poor little ct9b has been boosting to 12psi from what i have been told they dont have a long life boosting at that pressure ? Thanks Matt . crossfadeoil seals on turbo probably gone and and allowing oil to pass through them. check your turbo to intercoler pipe, if theres alot of oil then seals have gone. also if dump valve is spitting oil thats a sign of turbo going i believe.12 psi shouldnt be much of a problem tbh. 14.5 psi (1 bar) is where you start to reduce the little ct9's life so ive heard. Quote
chr15_7_t_ Posted February 20, 2010 Posted February 20, 2010 u could take the car for a compression test to make sure that the engine is ok Quote
Carl. Posted February 20, 2010 Posted February 20, 2010 other smoking could be caused by*worn piston rings as you said (checking compression would be a good idea)*pcv valve blocked*valve stem seals gone (try taking the car for a drive, pick up some speed and drop it down a gear and let it slow down with engine braking, if it smokes more when you do this then valve stem seals will be bad.)*head gasket (check for mayo looking gunge round oil filler cap)quite a few possiblities to be honest and lots of ways of testing. search on here theres loads. Quote
Crossfade Posted February 20, 2010 Author Posted February 20, 2010 cheers guys i will do the checks at my work . im a mechanic but havnt got a clue with the ep,s lmao .Cheers guys. Quote
