A rachet with a 10mm socket, maybe an inch extension or just a deep socket. Pop the clips off in the corners of the tailgate on the inner side, undo the bolts and unclip and brake light and then just push up on the spoiler and it will pop off. It isn't bonded on from factory, it just has clips on it that's why you need to push it upwards.
Idrees
Thank god it's not bonded, it would be a nightmare to remove if it was! Just remember you need to push it upwards, it may be a little stiff but should be fine after a nudge or two. Good luck!
Idrees
