Opies have teamed up with Millers Oils to bring you this very special offer. Only available at www.opieoils.co.uk.
Until the 31st March 2010, order 5 litres of Millers CFS and you will recieve a 500ml bottle of Millers CVL Turbo Octane Booster FREE! (Normal Retail £11.59)
The Millers Oils CFS range includes the following grades 5w-40, 10w-40, 10w-60 and the NEW 10W-50.
Millers CFS is a competition engine oil formulated with 100% synthetic base fluids, including a synergistic blend of three esters combined with the latest additive technology for maximum performance.
The Benefits of using Millers CVL Turbo Octane Booster are as follows.
It Can be used with modern fuels to increase octane levels by up to 4 octane numbers (40 points).
Provides improved performance for race, rally or track day.
Provides similar flame front control as lead, thereby enabling engines to run more advanced ignition timing without danger of pre-ignition or detonation.
Mixes with leaded, unleaded, LRP and other fuels containing octane enhancing additives such as oxygenates, ethanol and MTBE.
Equally effective in modern engines fitted with knock sensors and catalytic convertors.
If you're looking for a bargain, take a look in our CLEARANCE section which has heavily discounted products for both Cars and Bikes, whilst stocks last.
With best regards,
The Team at Opie Oils
This is not valid for trade and cannot be combined with any other discount or voucher codes.
