Ryan Milne Posted March 8, 2010 Posted March 8, 2010 Heard this noise for quite a while now, and after fitting coliovers and fitting an anti-lift kit, the noise seems to still be there. It's only there when you turn the steering wheel about 45 degrees to the left. Im not sure if it may be the lower ball joint sqeeking or even track rod end. Can any one shed some light on this problem??? Quote
Ryan Milne Posted March 9, 2010 Author Posted March 9, 2010 did you grease up the anti lift kit bushes?Ye the noise was there before i fitted the kit I think it may be the steering arm or maybe the track rod end but was hoping someone on here has had this same problem to be sure before buying anything. Quote
chriswoodfto Posted March 9, 2010 Posted March 9, 2010 ive had the same since i put my anti lift kit and sus on, was told to spray wd40 in the top mount. have just this second finshed doin it, and as hard as i can push u[ and down on the front right end, no squeek, cant hurt to try that. Quote
Ryan Milne Posted March 10, 2010 Author Posted March 10, 2010 ive had the same since i put my anti lift kit and sus on, was told to spray wd40 in the top mount. have just this second finshed doin it, and as hard as i can push u[ and down on the front right end, no squeek, cant hurt to try that.Thanks for the tip but still sqeeking away!! Im sure it's coming from a worn steering component but gonna have to get underneath and check everything. Quote
chriswoodfto Posted March 11, 2010 Posted March 11, 2010 let me know how it goes as my squeek is back, lol. Quote
Ryan Milne Posted March 13, 2010 Author Posted March 13, 2010 let me know how it goes as my squeek is back, lol.Fitted Bc coilovers and found that the sqeek is the brakeline rubbing against where they should be attached to the strut. Cable tied hard against the strut and the noise is away Quote
