Hi :)
Basically i found a glanza,talkd 2 the owner,arranged 2 have a new MOT on it (As he sed it expires end of this month) then he gets in touch with me today and tells me he cant put a new MOT on it cus he found out it actually goes out in July :S I suppd 2 be takin it away this Fri :)
What are the main things i want to check on it if i still go up friday?
Please help :(
Thanks
Matt
Guest cheshireglanza
anyone have any ideas?
i bought glanza with 2 weeks mot on it booked it in i was thinking its going to fail on loads passed first time
if he going to service it that should cover any faults it might have
thers not alot you can do relli apart from pay to get it fixed on the things it fails on (if it does) lol main things i checked when i got my glanza is when you turn up make sure the cars cold if its not then i wouldnt test drive it til it is as you wana be listening for any knocks or anything like that, check for oil leaks under the car or in the engine bay, when i went to see mine i got my boyfriend to take it out first so i could see if ther was any smoke cuming from the exhaust if ther is i wouldnt get it. you could always take a compression test with you and do one on the car to be safe :)
Yeah cus im guna check the car preety good first (ive gt a engineer 2 cum with me 2 check it) Then test drive it then check it again after, Are there any things on glanza 2 mainly look out for?
well if youve got someone in the know going with you then you should be ok :) and tbh i didnt really find anything when researching them
Im hoping all goes well :) Im meetin the guy at his dads place 2 save me some time traveling 2, im going to ask him 2 bring sum proof os his actaul address 2 :( What documents should i recieve of him? (service history,logbook,MOT, import papers etc)
Thanks
well yer obviously the v5, mot papers if hes kept them and obv if its still got mot on it u want the mot paper, mine didnt come with any service history apart from a couple of receipts as the kid was an idiot! but all depends what the persons like your buying it from and if theyve kept paperwork or not, id do an h.p.i. check on it to, and a logbook is a v5 mate lol
main things to check on is when driving check its boosting properly and holding the boost. then you know the turbos ok. also check theres no smoking when its cold that will tell you things like the stem seals are fine piston rings etc. check its not smoking on boost. again shows a healthy turbo
Full lock it both ways and do a circle. listen out for knocking which will tell you driveshafts are naff
check the engine bay for signs of leaks/cracked pipes etc and also check the oil for signs of water ( broken headgasket)
then just have a general check round
your engineer should look out for all these anyway
good luck dude
