Good Morning
Need help please, Lift my bonnet release catch, pops up slightly so i can then push up the lever. The problem is that it wont budge so i cant get to the engine bay. Any ideas to get this lifted without going to a garage?
Cheers
Tbh you should check where the lever is catching.
normaly you can see through the grill if the lever is moving or not... if its stiff hit it with some wd40.. level it for some time.. try again.
if the lever aint moving... pop a screw driver in to release the catch.
once you get it open... fire grease in about it... you shouldnt have any problem there after.
