chriswoodfto Posted April 6, 2010 Posted April 6, 2010 hey, ive had to replace the back to shocks as theyd strated to split, the fronts are on there way out to but are fine for a little while. so to keep costs down because im absolutly skint at the minute. can i replace the front shocks with the kyb damper adjustable ones first. and then replace the back shocks (to the same kyb adjustable ones) a couple of weeks down the line. would it be ok to do this? anyone running these? what are they like? i dont wan go down the coilover route as theyll be too hard for my daughter and the roads just aint good enough to handle them either, Quote
Glanza_cl Posted April 6, 2010 Posted April 6, 2010 it's not ideal but you will be fine mate, there could be a height difference and i wouldn't push the car round any corners particularly fast as the difference in shock and spring set up could make the car easily unbalanced.but to tide you over till they are all replaced it will be fine. Quote
chriswoodfto Posted April 6, 2010 Author Posted April 6, 2010 hmmm, might just buy the fronts now and wait 4 weeks till i can buy the rears too. Quote
