silverglanza Posted April 7, 2010 Posted April 7, 2010 hi guys i got a hks turbo timer not the thin black one like a sqaure box old school one i got a turbo timer harness pluged it in to my ignition barrel got the car runing power going to the turbo timer turn the ignition off power dies to the timer all i got 3 wires spare with funny connectors on one wire is grey other one is brown other is blue i thort you just plug it all together and its done anyone help me please? Quote
DannyGlanzav Posted April 7, 2010 Posted April 7, 2010 one of the spare wires will be an earth that goes to the handbrake mate Quote
Scratchy Posted April 7, 2010 Posted April 7, 2010 one of the spare wires will be an earth that goes to the handbrake matethe grey wire goes to the handbrakehandbrake has to be on for the turbo timer to kick in, same problem i hadhope this helps Quote
silverglanza Posted April 7, 2010 Author Posted April 7, 2010 the black wire i got is a eath once it touches metal the turbo timer lights up what can i do to make the turbo timer aactully work it all lights up and all just once the keys are taken out the timer just turns off with ignition doesnt stay on and let it cool can i link these wires out somehow? Quote
Scratchy Posted April 7, 2010 Posted April 7, 2010 the black wire i got is a eath once it touches metal the turbo timer lights up what can i do to make the turbo timer aactully work it all lights up and all just once the keys are taken out the timer just turns off with ignition doesnt stay on and let it cool can i link these wires out somehow?you need to run the grey wire from the harness to the handbrake which in mine was tinyu need to wire it in to probably more wire first before you can run it to the handbrake.you then need to create a circuit with the hand brake. ie join them together you can do this by clamping both wires together creating a circuit, u can get tiny wee blue wire connecters at places like B & Q and homebase did the job perfect for meand for the turbo timer to work u need to hav the handbrake Appliedthis will sound like a proper mind fuk but ill try get photos up for u tomorrow make it easier for u to followwire connecters:----is this the turbo timer u hav? Quote
Guest ep82_girl Posted April 7, 2010 Posted April 7, 2010 scratchy that has confused me and i have a turbo timer!!! loli know that once the hand brake is released the turbo timer should knock off for safety reasons but apart from that im uselessxxx Quote
Scratchy Posted April 7, 2010 Posted April 7, 2010 scratchy that has confused me and i have a turbo timer!!! loli know that once the hand brake is released the turbo timer should knock off for safety reasons but apart from that im uselessxxxit will all make sense tomorrow when i get the pics up Quote
jobo Posted April 7, 2010 Posted April 7, 2010 he basically means its got to completethe circut to make it stay on when you take the key out if you imagine h'brake power signal going this way -> ____/ ___ turbo timer the broken section of the line is the hand brake wire /\if the circuit is broken as shown then the timer wont stay on because it doesnt get a signal from the grey wire, therfor it just goes offbut if it gets a signal it stays on and should work(sorry for the improv pic) Quote
silverglanza Posted April 8, 2010 Author Posted April 8, 2010 so i just need to run a grey to hand brake and joint it to the handbrake cable ? and it will stay on and work correctly? Quote
Raz Posted April 8, 2010 Posted April 8, 2010 just a question, how come on my automatic one it doesn't require the handbrake to be applied. Quote
jobo Posted April 8, 2010 Posted April 8, 2010 when in park its the same idea as the handbrake , somthing to do with the wiring i think Quote
