essex stu Posted October 8, 2006 Posted October 8, 2006 Hello everyone, how much to get the headgasket repaired, water pump replaced and radiator replaced. And where can I get a radiator and water pump from because I already have the head gasket set and new valve etc. thanx everyone Quote
Shaun Posted October 8, 2006 Posted October 8, 2006 Hello everyone, how much to get the headgasket repaired, water pump replaced and radiator replaced. And where can I get a radiator and water pump from because I already have the head gasket set and new valve etc. thanx everyonealot of money mate you will need the head shimmed and presure tested that will be about 60 to 80 pound then about 3 to 4 hours labour avout 44 pound a hour depending where you go to have it done. Quote
essex stu Posted October 8, 2006 Author Posted October 8, 2006 Do you think the lot will come to under 500? Quote
Spuddy Posted October 9, 2006 Posted October 9, 2006 Expensive labour costs in England! My mechanic only charges £15 an hour Quote
