Hi there i was wondering if anyone cud help me? I have recently got myself a ep82 and have noticed that both high and low boost are 0.5 can anyone tell me how i can set the boost up or what could be causing the problem.
cheers steven.
cheers steven.
engine specs?
to adjust boost u need an adjustable actuator, the actuator is located on the turbo and is a small cylinder shape with an arm sticking out of it with is connected to a lever controling the opening of the wastegate. if yours has a threaded arm that can be adjusted simply disconnect it from the lever and screw it inwards to increase boost. if you have the standard actuator i recommend getting an adjustable one as their crap at holding boost and could be why your only boosting .5
engine specs?
Hi cheers for your reply ive ad a look ad it does seem to ave an adjustable actuator so ill ave a go at ajustin it slightly.
Im not too sure what the spec of the engine as ive not ad it long so really need to get some one to give it a once over. Ive been reading a few posts and the hose from the actuator goes straight to the turbo so i gather this is why its only boostin at .5 on both high and low, so to cut a long story short is it a good idea to get a boost controller if i want the high/low
cheers steven
