mizlopi Posted April 19, 2010 Posted April 19, 2010 Can anybody tell me wot to use to take off the steering rod end off the ep91 because ive got so far and i cant get anything on it?? Anybody done it if so wot with? Quote
scot-ish Posted April 19, 2010 Posted April 19, 2010 track rod end? sure its just a spanner, and for the bottom bolt, just a spanner, and then hit it with a hammer Quote
mizlopi Posted April 19, 2010 Author Posted April 19, 2010 No ive got that off but the rod that the track rod end is on i need to take off (tie rod) there is a place you can get grips or spanner on but once you turn it so far its almost impossible to get to to turn it more? Quote
mizlopi Posted April 19, 2010 Author Posted April 19, 2010 Ye spot on mate!! Its the red part at bottom ye n/s one got nut off tapped it out but other end going onto steering rack is hard to get to Quote
scot-ish Posted April 19, 2010 Posted April 19, 2010 it looks like you will need two bolts on the other end locked tight, and then screwed off, looks from the pic its got a thread into the rack.ive not removed one, but makes sense that it would be threaded in Quote
scot-ish Posted April 19, 2010 Posted April 19, 2010 You'll have to crack the lock nut off before removing the joint from the hub (this stops the track rod from spinning). Once the lock nut is loose, remove the joint from the hub and wind it off of the rod. If it's still a little tight then you may need to hold the track rod with a spanner (possibly a 12mm) and turn the track rod using the correct size spanner (possibly a 17mm). After you've replaced the track rod and track rod end, you'll need to have the front toe adjusted back into spec, although as a temporary measure, if your eyesight is good you can adjust it yourself by setting the steering wheel in the straight ahead position, then winding the replaced track rod in or out until the wheel appears to be sat in the same position as the wheel on the other side. It's not a totally accurate way of doing things, but it's better than leaving the wheel pointing out on the piss. After each adjustment, turn the steering full lock both ways and then recentre the steering wheel before deciding if the adjustment made is enough or too much.see here, http://www.toyotagtturbo.com/forums/showth...emoving+tie+rod Quote
mizlopi Posted April 20, 2010 Author Posted April 20, 2010 Cheers mate ill give it a bash!! Thanks for the help lads Quote
