Ecu Reset Rough Idle
Hi, hope somone can help, i have an unsteady idle witch is realy anoying. The car is a completley standard 1998 EP91 manual turbo. It has recentley had new plugs, leads, and injecters cleaned. This was before i purchased the car. My question is , if the injecters are cleaned does the ecu need to be reset for the right fuel air mix. or do you think it is the idle control valve. If the ecu needs reseting does anyone know the procedure. Cheers
might be wrong but was told the efi fuse can reset some things codes memory ect give the idle control valve a clean they get a lil oil and carbon in them over time someone may put me wrong
try cleaning the throttle body with carb/intake cleaner
p.s/ i really really doubt resetting the ecu will do anything at all. but if you want to do it just disconnect the battery for 15 - 20 mins
