olij360 Posted May 2, 2010 Posted May 2, 2010 Hey guys,I've been working on my starlet now for last month builing it up from standard, but as things go needed a new clutch so mate of mines fitted it for me done a great job apart from now nothing works, car starts and drives fine, the headlights work and so does the interior light.The clock and rest of dash doesnt light up rear lights/brake/reverse inicators and sound system dont work.he seems to think theres a problem with an earth but they all seem fine :S and he got fix it till next week can anyone help me cheersolly. Quote
andy.i Posted May 2, 2010 Posted May 2, 2010 check your fuses. also there is an earth strap that goes onto the gearbox from the battery, make sure its connected Quote
Raz Posted May 3, 2010 Posted May 3, 2010 The clock and rest of dash doesnt light up rear lights/brake/reverse inicators and sound system dont work.Hey man, That is the exact thing we fixed today on a Diesel Starlet (EP82). The problem we had was the guy tried to put a stereo in. He burnt 7 or 8 wires completely leading to the ignition barrel or around the steering column connectors. We stripped the dash and went onto fault finding and we found all these naked burnt wires. The matey had snipped a wire from where it connects into the male female connector because it kept blowing fuses. All we did is replace all the burnt wires making sure they not touching together and the bit he had cut was for the acutual rear end lighting so we soldered abit of wire and the problem was sorted. Quote
brammall Posted May 3, 2010 Posted May 3, 2010 main fuse - check that, same thing happened with my mates, only headlights worked and nothing else. Quote
Steve GT Posted May 3, 2010 Posted May 3, 2010 yep same thing happened to me it was the main fuseif you loook under the engine bay on the far right hand side theres a black box of fuses. have a look at the 2 biggest ones, i think there red and black check them matey sounds like the problemyou havnt crossed the polarity on the battery have you this is usually the reason to blow them fuses lol Quote
olij360 Posted May 3, 2010 Author Posted May 3, 2010 yep same thing happened to me it was the main fuseif you loook under the engine bay on the far right hand side theres a black box of fuses. have a look at the 2 biggest ones, i think there red and black check them matey sounds like the problemyou havnt crossed the polarity on the battery have you this is usually the reason to blow them fuses loli couldnt tell you mate, my pal fitted a new clutch so no doubt it has done somthing like that, how do i check them fuses as they aint like the small ones wher u can see if they have blown ? Quote
panda man Posted June 3, 2010 Posted June 3, 2010 main fuse - check that, same thing happened with my mates, only headlights worked and nothing else.yes! that was me........bodged Quote
