leasky29 Posted October 19, 2006 Posted October 19, 2006 hey i was wondering what would i need to do to a 5efe engine to turbo it, would i need a new clutch an fly wheel, an can i still use the 4efe gearbox, cause im thinking of putting it in a standard uk spec 4efe an can i get away with not using a cat, and is there any other stuff i need to sort out on the car as well Quote
sr-starlet Posted October 19, 2006 Posted October 19, 2006 i have been trying to source a 5efe engine for a while with little luck if i were you either buy a gt turbo or glanza. sorry not alot of help Quote
Guest Enzo Posted October 26, 2006 Posted October 26, 2006 soory ive only just noticed this thred mate,there are loads of 5efe engines kicking aobut you just need to know where to look ot find themin regards to turboing a 5efe it can be done but ud be better off with an fte as it was designed to take boost, if you were going for light boost aplications like anything upto standard boost then you hsould be fine,to turbo from memory you would need mani, turbo, oil lines, fte sump among other things, the fe inlet manifold is mega restrictive so you would need to utilise an fte one too,hope that has cleared up your queestion,any more just ask Quote
