silverglanza Posted May 30, 2010 Posted May 30, 2010 i was driving my car today seemed hard to ingauge the gears i went to change down and couldnt get it in gear went in gear then i floored it revs shot up like it was out of gear i can put it in 1 2 3 4 5th with the cluctch all the way up nothing is this just a clutch or gear box? bit of bad luck wasnt exspecting it to happen so early as there was a 6month old standerd clutch in it aswell Quote
james@cjperformance Posted May 30, 2010 Posted May 30, 2010 i was driving my car today seemed hard to ingauge the gears i went to change down and couldnt get it in gear went in gear then i floored it revs shot up like it was out of gear i can put it in 1 2 3 4 5th with the cluctch all the way up nothing is this just a clutch or gear box? bit of bad luck wasnt exspecting it to happen so early as there was a 6month old standerd clutch in it aswellif the revs just shoot up when it is in gear i would think it was the clutch give me a pm if you want a hand fitting a new one ;) Quote
Steve GT Posted May 31, 2010 Posted May 31, 2010 check underneath for leaking gear box oil/engine oil. could be the clutch spinning due to leaking gear box oil from the seal or engine oil from crank seal. Quote
