Hello,
I want to Place a Decat on my Build Glanza..
But i need to know what the size is of the Bolts for a Decat so i can replace them..
I know that there are 4 bolt on the turbo and 3 to the exhaust..
But the size i don't know..
Can Someone help me ?
Greetings,
Jeroen
  • 2 weeks later...
you dont really need to replace unless they rounded or broken which i hope its non of the both pm me as a reminded and i will check 2moz im sure the 3 bolts are 14mm and the turbo side are 12mm bolts all recheck 2moz but the turbo side and exhaust side are nuts not bolts but either way you can put bolts if you remove the studs
Hello,
Greetings,
Jeroen
there are no bolts.... hehe, studs and nuts are used, and you want toyota originals tbh, there the best quality, better than anything ule get out of halfords etc, i cant remember the part numbers but thats what you want
