glanza.jack Posted June 9, 2010 Posted June 9, 2010 Not sure if im in the right section here?Where can i buy sealer for my car? I am planning on fitting a roll cage and want to seal drilled holes.. Quote
Minorand944man Posted June 9, 2010 Posted June 9, 2010 Not sure if im in the right section here?Where can i buy sealer for my car? I am planning on fitting a roll cage and want to seal drilled holes..You can get seam sealer 1litre brushable tin should be enough, from any automotive paint supplier or parts supplier. Look them up in the yellow pages. Or if you want to buy online, Frost do brushable seam sealer as well as seam sealer in a tube.brushable http://www.frost.co.uk/item_Detail.asp?pro...er%20(1%20kilo)POR15http://www.frost.co.uk/item_Detail.asp?pro...Black%20(118ml)Squirtable seam sealerhttp://www.frost.co.uk/item_Detail.asp?pro...Black%20(310ml) Quote
hulahoops Posted June 9, 2010 Posted June 9, 2010 depends where your based... in scotland u would get it from big manufacture company dingbro.. or if u go into your local autopart im sure u would find sealer in there dude but remember and get the proper sealer. Quote
Minorand944man Posted June 10, 2010 Posted June 10, 2010 depends where your based... in scotland u would get it from big manufacture company dingbro.. or if u go into your local autopart im sure u would find sealer in there dude but remember and get the proper sealer.hulahoops is right, get the proper seam sealer. The stuff I linked to is overpaintable so you can spray it the same colour as your car paintwork or the same colour as the roll cage if you prefer for a neat job.The wrong stuff, which is the cheap nasty black underseal is not overpaintable and does not seal very well at all. Quote
