cars been driving fine alday slowed down for speed bump then started 2 pull away in second just as i started to come on to boost car violently juddered been doing it in every gear since any help would be appreciated . mods are blitz filter & dump valve a/c removed 1&2 restriction remove thats about it.
actually just changed oil, oil filter and plugs about 3weeks ago to bosch super 4s but was misfiring/coughing so changed them back to the hks ones that were in and was running fine until now ??
check the plug gaps, and also for water contamiation in the dizzy cap, i found this with condesation and jetting the engine bay of, if you have accessiblity to a air blower, blow down all the plug holes inside the dizzy and spay some wd down the coils, after that check that nothing has come a drift i.e. leads or wiring to air flow meters and map sensors
let us know how you get on
