Well i get home today and my lovely boyfriend had a suprise instore for me a Glanza at a bargain price which he was not gonna turn down.
One main problem the crank shaft is broken and was wondering how big of a job it is to sort or any idea about what i need to do??
HELP..........
its an engine out job well thats the way i would do it to make it easier to work at
and if your doing that much work might aswell put new piston rings in it and get the head checked out and i would do valve sems aswell
list of thing i would do while doing it
new timing belt
new headgasket
new valve stems
new piston rings
water pump
oil pump
block and head checked for warping and leaks
new headbolts
there is prob more you could do just depends how you want to do the job i would want to do it just the once rather that put crank in it and find out there is a piston ring gone or something of the sort.
hope that helps
joel
new timing belt
new headgasket
new valve stems
new piston rings
water pump
oil pump
new headbolts
hope that helps
joel
thank you muchly maybe new engine job :lol:
