glanza.jack Posted June 20, 2010 Posted June 20, 2010 Just plumbed in my boost gauge but want to wire up the light. whats the best way to do it, on my old car is was wired into my lights so when i switched them on it was turned on or i have been told to wire it onto the ignition cable?? im useless at electircs so dont know what wire to be looking for.. are they an obvious colour?Whats best or if anyone has better ideas.... Quote
glanzav.tee Posted June 24, 2010 Posted June 24, 2010 Just plumbed in my boost gauge but want to wire up the light. whats the best way to do it, on my old car is was wired into my lights so when i switched them on it was turned on or i have been told to wire it onto the ignition cable?? im useless at electircs so dont know what wire to be looking for.. are they an obvious colour?Whats best or if anyone has better ideas....you could wire it up to the back of your instrumental (dials) as long as its not an LED your ok as you have to look at palority but if its a normal bulb u can hook it up to that and put bulb back in when you switch lights on so will the guage if you stuck PM me i will draw u a diagram to help ya hope some of this helps ya Quote
