Will Abs Rear Discs Fit A Non Abs Ep82
  • 4 years later...
Sorry dragging this old thread up again but I've just done same. Some rear discs (+abs) landed in my garage but I have non abs car. Any problems since or does anyone know? I presume the abs ring just sits there redundant on non-abs?
Edited by Barnz74
  • 1 month later...
Yeah, the ABS ring will foul the backing plate. I removed the ABS ring from my discs and then they fit fine. (I put the disc with the ABS ring in a vice and just turned the disc with a long bar between the wheel studs. The vice prevented the ring from turning and in under a minute the disc was ABS-less)
