i am going to be putting the rear brake disc setup from a gxi on to my corolla saloon...
1) Is it a straight swap?
2) the rear discs and pads cost £££, is it possible to use discs from a different car (cheaper)? if yes which one?
this is off an ad of ebay for the size of the disc....
Mountings 4
Disc Diameter 266.0mm
Disc Thickness 9.0mm
Overall height 36.5mm
Centre Diameter 55.0mm
Minimum Thickness 8.0mm
Thank you !!
(thanks to whoever moved it)
ishaq
