string Posted July 30, 2010 Posted July 30, 2010 gettin my head round compressor maps. i worked out as 22lb/min or 320cfm.that goes on one axis. other axis is psi i wanna run plus 14.7 divided by 14.7 to give me the figure i follow. see if its in the efficeient isalnd and thats it or what?anyone explain how trims come into it or do they not. as in when i look at the desired turbo with trim its already there. like a 40 trims map is different to a 60 trim?or do i have to use an equation to work it out. cheers Quote
