PeteT Posted August 4, 2010 Posted August 4, 2010 I've been told that mk1 mr2 1.6 injectors fit in, and are a higher capacity than the standerd paseo one. Anyone know if this is true and if it is, will it make any difference?cheers Quote
Guest Enzo Posted August 4, 2010 Posted August 4, 2010 you dont need to uprate the injector, the standard ones are fine for any na tuning you can trhow at it Quote
steed Posted August 4, 2010 Posted August 4, 2010 the mk1 mr2 ones will fit but they are a different impedance, you'll need to add an extra resistor to deal with the load. Quote
PeteT Posted August 5, 2010 Author Posted August 5, 2010 cheers people, ill leave them as they are Quote
