lincoln wood Posted August 16, 2010 Posted August 16, 2010 hey guys hows it going i was wondering if any one would hook me up with a full list on wat parts i ould need to bulid a forged 4efte engine to make 300bhp got the money but not the knowledge on the engine bulid im a panel beater so know how to do the owt side but under hood not so much so any help would be much appreciated thanks Quote
drew 007 Posted August 16, 2010 Posted August 16, 2010 Welcome along dude,i hope you enjoy your stay try using the search option that go's down the left hand side,i will guarantee all your answers will be in there matey. Quote
lincoln wood Posted August 16, 2010 Author Posted August 16, 2010 thanks mate yea will do ive had a bit of a look around and theres answers everywhere Quote
drew 007 Posted August 16, 2010 Posted August 16, 2010 thanks mate yea will do ive had a bit of a look around and theres answers everywhereGood man,glad to here that dude. Quote
Steve GT Posted August 16, 2010 Posted August 16, 2010 According to the TM-Developments spec on a forged engine they build you will needAll engines stripped and thoroughly chemically cleaned. Block rebored, crosshatch honed. Forged low comp pistons, 74.5/75mm, forged rods. Crank reground (if needed) with all new bearings. Head stripped and cleaned, valves re seated, new valve stem seals, New Head Bolts. New Toyota oil pump, new water pump, new cam belt and tensioner kit, new oil sender switch, new thermostat. All new gaskets and oil seals. Metal head gasket 1.2/2mmOther extra options isPorted cylinder headLightened balanced and knife edged crankshaftBillet camsBaffled sumpCruise valve springsPower Enterprise Cam beltARP Head BoltsAs for turbo kits do a bit of research on the td05's they will easily get you 300bhphttp://www.tm-developments.com/index.php?m...products_id=415Hope this helps Quote
lincoln wood Posted August 17, 2010 Author Posted August 17, 2010 thanks mate this will help me get the ball rolling just gota get a engine first at the moment ive only got the trust old ep82 gi starlet i picked up for $400 does the job but i think its time to go all out and bulid a complete power pakage from the start wont be letting any secrets out but im doing a major over hall on the front end of the car to make it one of a kind will keep everyone posted Quote
