starlet enterprise Posted August 21, 2010 Posted August 21, 2010 Having some difficulties. Now as some of you no i was installing a new turbo well second hand unit now after install everything up the damm thing just wont boost. ive checked all pipes etc and it just wont boost past 0 so i checked the external wastegate took spring out it was okay then with it off i revved it the part inside wastegate when revved with no pressure on it opened up (to sound like a tractor) lol so i put my finger over it and went to rev it nothing happened it would push against my finger. unsure if its meant to do that, next tried disconnect the pipe from the boost controller to the wastegate, blocked it off and still no change, i also took all piping of the wastegate that feeds to turbo and it didnt work also. on this turbo the only place i could see to run the ext wastegate pipe to the external wastgate was on the plastic pipe that bolts onto the turbo, rather having cast tube running down for intercooler this has a bolted on part. i just cant think of anything else thanks for taking time to read this chris Quote
string Posted August 21, 2010 Posted August 21, 2010 pics mate. Then we might be able to help. Safe Quote
starlet enterprise Posted August 21, 2010 Author Posted August 21, 2010 pics mate. Then we might be able to help. Safeill get some pics up asap, everything is plumbed back in correctly from what it came from Quote
Guest Enzo Posted August 21, 2010 Posted August 21, 2010 What brand of extrernal gate have you got?What brand of extrernal gate have you got? Quote
starlet enterprise Posted August 21, 2010 Author Posted August 21, 2010 What brand of extrernal gate have you got?What brand of extrernal gate have you got?its the tial enzo Quote
starlet enterprise Posted August 21, 2010 Author Posted August 21, 2010 to add i made a custom style turbo for this setupin this thread http://www.ukstarletclub.com/forums/index....showtopic=33244 Quote
scot-ish Posted August 22, 2010 Posted August 22, 2010 maybe the blades dont fit the comp housing properly mate, or the exhaust housing, if its not a tight fit, it wont compress = no boost. Quote
