if you just weld a pipe to the decat it will sound like a tractor at idle unless you seal the wastegate flap seperate to the turbine.
even then its not that likely to form a tight seal
best ways external wastegate. sounds amazing
Marck
bit off topic but does the length affect the sound? Like racetech look long compared to keiths stubby ones.
I dont think there are performance gains to be had, perhaps if you had a restrictive exhaust system it would help take the strain of by venting to atmosphere.
