right my engine managment light comes on now and then and its fault code 52 which i just read somewhere is knock sensor
can someone explain waht is causing this?
im getting a new engine this week, will this solve the problem?
thanks in advance guys
no from memory you will have to get under the car to see it properly, its right at the back of the engine iirc.
i was getting code 52, and checked the knock sensor and the wiring had come loose
