BFannon Posted October 2, 2010 Posted October 2, 2010 anyone got a photo of the injectors? as i am not sure if mine are plugged in the correctl order?as the car aint running properly could this be the problem? also spark plugs are black!any help rep added accordingly Quote
BFannon Posted October 4, 2010 Author Posted October 4, 2010 no one? just need a pic of the injector plugs! so i can see the colours of the wires that enter the injectors!Bill. Quote
BFannon Posted October 4, 2010 Author Posted October 4, 2010 well what it is i am using the GT engine wiring loom on the glanza V engine! i have already tranfered all the correct thermostat housing and sensors over! brought bramd mew from toyota! so the injector harness would have been plugged in by my mate! so wanted to double check!also tonight i took my turbo + mani +sard sports cat off, as i has a major leak coming from the mani to tubby gasket! so i renewed it while i was there i thought i would port the wastegate a little to stop the little boost creep i was getting during the colder months! but when i took the tubby off the mani and the sard cat i noticed it was incredibly sooty! not like normal amount of soot! is this normal i took pic to try and show but not the best quality!is this right? also my spark plugs are covered in the same soot!does that look normal? first time i had my tubby apart! lolBill. Quote
