Daniel. Posted October 7, 2010 Posted October 7, 2010 the car warms up all okay, heaters work and so on, but the temp gauge hardly moves, if not at all, gets up to about quarter of the way, could it be the thermostat or the needle? if its the thermostat, how hard are they to get to? any handy guides?worth doing the thermostat anyway?thanks in advance.. Quote
Asad Posted October 8, 2010 Posted October 8, 2010 You may aswell change the thermostat They are cheap enough if left they can be really naughty also change the coolant n throw some new hoses on while your at itfollow the bottom rad hose up you'll see 2 10mm nuts undo them and there's the thermostat make sure the seal is Ok If that doesn't sort it then it's defo an electrical unless the gauge reads off one of the other sensors Quote
Daniel. Posted October 8, 2010 Author Posted October 8, 2010 cheers, ill have a look, i cant find a thermostat for a 4EFTE, i guess they're the same as the 4EFE ones? Quote
