hi
got a issue with my coilovers , when i first got them they were all at the standard setting , but i wanted it lower so i made a mark on the coilover and counted the turns and the o/s/r seems to be lower then the n/s/r ??? i reseted them and the o/s was still lower :harhar: i hurd it could be something to do with the rear axel??? help
Your best bet would probably a whiteline adjustable one. Once you've got it, get under the car and look in front of the back axle and you'll see a bar bolted to the axle on one side and bolted to the chassis on the other side of the car and thats the panhard rod. Piece of piss to do :harhar:
