little lews Posted October 27, 2010 Posted October 27, 2010 well I've bout a werp mani with e/w and i need a e/w screamer pipe and down pipe and I've bean told this is good wastgate Supplied with 2 gaskets, 2 NPT fittings, valve seat, mounting bolts and a 7psi spring turbosmart can i run 1.2 bar with this wastgate anyone help Quote
Ryan Posted October 29, 2010 Posted October 29, 2010 yeah mate you can use a boost controller to raise the boost above the spring pressure.You might be better of with a stronger spring tho the 7psi might be a bit weak to hold 1.2bar. I would get a 0.9 bar spring or a 1 bar spring for it Quote
