Raz Posted November 17, 2010 Posted November 17, 2010 I moved it all the way down so all the adjusting ring things are touching each other, i did not fiddle with the spring pre-load. Now when going over bumps its making a clicking noise as if the rings are banging against each other. Or the wheels are touching somewhere? but i have seen lower starlets. I also stiffened the rear end so it doesn't try to smooth bumps and cause the tyre to rub.Are the rings ok touching each other or should there be a gap between the height adjustment and the spring pre-load rings? Quote
Raz Posted November 17, 2010 Author Posted November 17, 2010 ok, i just came back from raising it. I moved up about a 2mm so now there is a gap (of 2mm) between the spring pre-load ring and the height adjustment ring on either side. It doesn't make the noise as much but it still does it a fair bit. Whats going on? Is it scraping somewhere? Quote
