little lews Posted November 30, 2010 Posted November 30, 2010 were car i get any pic or vide of someone fitting a td04 kit cus i cant find anythink can anyone help me pleasecus im dopey as fuck thanks Quote
StarletMad Posted November 30, 2010 Posted November 30, 2010 lol i really dont think you'll find one either unless theres one about 6-8 hours long!i knew i should have taken pics when i done mine!! Just use your common sense and dont be silly!Remove batteryEmpty system of water + remove radiatorRemove FMIC pipe that joins the turboRemove Air FilterRemove Water Feed/Return pipes to turbo Undo Banjo Bolt on the block (oil feed)Take off Oil Return pipeUndo ExhaustSlacken off Manifold BoltsUndo the turbo support barsBe sure to take the weight of the turbo and manifold though! as the studs dont like it much ;)Thats just removing your standard on lol! Quote
