jibend Posted December 10, 2010 Posted December 10, 2010 http://cgi.ebay.co.uk/JDM-Toyota-EP91-Star...=item20b54cc9b0http://cgi.ebay.co.uk/JDM-Toyota-EP82-Star...=item518e685b50would any of them work on the standard 4e-fe engine by just taking out the old ecu and replacing it with one of these?im real newbie on these so just trying clear things up thanks Quote
Idrees Posted December 10, 2010 Posted December 10, 2010 The plugs are different and the map will be for a turbo application, so you wouldn't really want to fit that to your N/A anyway. Quote
jibend Posted December 10, 2010 Author Posted December 10, 2010 alright then cheers fella. and what if i wanted more power from the standard n/a which ecu would i need? thats if you can? Quote
Kennedy Posted December 10, 2010 Posted December 10, 2010 ^^You'd need a standalone ECU..if you want more power drop a 4EFTE into it. Quote
jibend Posted December 11, 2010 Author Posted December 11, 2010 what and the standalone would just simply plug in as the standard one? and how much more power would it roughly give? and yer the 4e-fte isnt cheap online XD plus i think youd need allot more things replacing then just than just the engine... ^^You'd need a standalone ECU..if you want more power drop a 4EFTE into it. Quote
Kennedy Posted December 11, 2010 Posted December 11, 2010 You need something like an emanage, would need fitting into the ecu loom then mapping. How beneficial it would be to an N/A I don't know. Quote
jibend Posted December 11, 2010 Author Posted December 11, 2010 alrite then cool, ill look around and see what pops up cheers buddy. thanks Quote
