waste gate? are you running externally gated and mean the screamer pipe is plumed back into your down pipe?
all internal waste gates will flow into the down pipe... hence why i ask do you mean screamer?
either way no not really lol, just means you wont hear the screamer as it will be diverted down the exhaust.
Seeing as the internal wastegate dumps into the downpipe i couldnt see this setup giving it a bit more grunt. If you want more noise let the external wastegate dump into the atmosphere through a screamer pipe
