You can only run above spring pressure mate so no if you want lower boost you need a lower rate spring
I brought a new tial wastegate which was on offer at £155 but only came with a 1 bar spring.
so if i buy a 0.7bar spring and fit that then i should be able to turn the boost up a little to 0.8 on my boost controller?
Thats a good price!!
Yea basically gotta undo the screws take the top off and replace but its a nightmare compressing the spring to get tohe top back on so I am told.
Yea if you got a .7bar spring then you can run above .7 with a bleedvalve/boost controller etc
was from turbo dynamics
Cheers for the info buddy.
