steady_eddy Posted December 27, 2010 Share Posted December 27, 2010 if i have a external wastegate with a 1bar spring will my turbo only run at 1bar of boost or more? or could i turn the boost down with an electric boost controller? Quote Link to post Share on other sites
Sparky Posted December 27, 2010 Share Posted December 27, 2010 You can only run above spring pressure mate so no if you want lower boost you need a lower rate spring Quote Link to post Share on other sites
steady_eddy Posted December 27, 2010 Author Share Posted December 27, 2010 You can only run above spring pressure mate so no if you want lower boost you need a lower rate springI brought a new tial wastegate which was on offer at £155 but only came with a 1 bar spring.so if i buy a 0.7bar spring and fit that then i should be able to turn the boost up a little to 0.8 on my boost controller? Quote Link to post Share on other sites
steady_eddy Posted December 27, 2010 Author Share Posted December 27, 2010 also how easy or hard is it to change the spring? is it a case of undering some screws and changing? Quote Link to post Share on other sites
Sparky Posted December 28, 2010 Share Posted December 28, 2010 Thats a good price!!Yea basically gotta undo the screws take the top off and replace but its a nightmare compressing the spring to get tohe top back on so I am told.Yea if you got a .7bar spring then you can run above .7 with a bleedvalve/boost controller etc Quote Link to post Share on other sites
steady_eddy Posted December 28, 2010 Author Share Posted December 28, 2010 Thats a good price!!Yea basically gotta undo the screws take the top off and replace but its a nightmare compressing the spring to get tohe top back on so I am told.Yea if you got a .7bar spring then you can run above .7 with a bleedvalve/boost controller etcwas from turbo dynamicsCheers for the info buddy. Quote Link to post Share on other sites
